A VRRP router configured with fabric routing mode will be in backup state. There is some difference in behavior based on enabling sequence which is described below.
For the duration it waits in backup state, traffic will be forwarded to the VRRP master where it gets routed. This behavior is same as existing behavior without fabric routing.When configuring fabric route mode when the VR is already in backup state, if the VR has received advertisements within the last advertisement interval, the router will take forwarding responsibility immediately.
The hold off timer will be applied before FREB starts IP forwarding. In case of reboot or process restart, the VR will wait for 60 seconds before taking forwarding responsibility. This will allow the routing protocols in the restarting system to converge.
To enable fabric routing, use the following command:
configure vrrp vlan[ vlan_name | vlan_list] [vridval | all} {group group_name}fabric-routing [on | off]
configure vrrp vlan v1 vrid 1 fabric-routing on
To configure all the VRRP instances as FREB:
configure vrrp all fabric-routing on
Configured fabric routing can be seen in the show command output of the show vrrp detail or show vrrp vlan vlan CLI command:
# sh vrrp detail VLAN: v1 VRID: 1 VRRP: Disabled State: Backup Virtual Router: VR-Default Priority: 100(backup) Advertisement Interval: 1 sec Version: v2 Preempt: Yes Preempt Delay: 0 sec Virtual IP Addresses: Accept mode: Off Host-Mobility: Off Host-Mobility Exclude-Ports: Tracking mode: ALL Tracked Pings: - Tracked IP Routes: - Tracked VLANs: - Fabric Routing: On * indicates a tracking condition has failed
